How to create a dump file from a controller that includes only the commissioning information of i2/b3 devices.
  • How to create a dump file from a controller that includes only the commissioning information of i2/b3 devices.
  • AbeMeran
    AbeMeran
‎2018-09-06 10:37 AM
Site has existing CX/bCX with many i2s/b3s on field bus that need to be moved to a different CX/bCX, want to create a dump file from the existing CX/bCX that can then be imported into the new CX/bCX to create the devices and then do a 'Send to database' from the devices once they are online in the new CX/bCX.
CyberStation
CX9xxx
bCX4xxx
bCX9640
Documentation
  1. In the Continuum Explorer expand the existing CX/bCX then click on the InfinityInfinetCtlr folder.
  2. Pull down the 'Options' menu and set the 'Send To Text File Options' to DO NOT DUMP CHILD OBJECTS
  3. Select ALL the field devices on the right pane, right click and perform a 'Send to Text File' operation
The resultant .dmp file when imported into the new CX/bCX will create all the field devices using the same names and ids they had in the old CX/bCX
NOTE:
The file may have to be edited to match the Network/Controller name.
  • 12638
