How to configure logs to update only on value change.
  • How to configure logs to update only on value change.
  • AbeMeran
    AbeMeran
‎2018-09-06 01:19 PM
  • All CXs
  • All i2s
  • All b3s
Only logging a new value when the value has changed is useful to save on memory usage. It is also preferable in most binary value trends.
Configure the point's log as type = LogInstantaneous AND Interval = 0 days 0 hours 0 minutes 0 seconds.
This is referred to as a semi-log configuration.
  • 6139
