How to clear the controller flash backup from the hardware using the reset IP switch.
  • How to clear the controller flash backup from the hardware using the reset IP switch.
  • AbeMeran
    AbeMeran
‎2018-09-06 12:57 PM
CX9640
CX9680
CX5720/40
Need to remove any backup in flash but has no access to the controller's web page configuration.
Pushing and holding down the controller's reset IP switch for 30 seconds clears any backup of the database in flash in addition to resetting the IP address and ACC node id.
  • 6822
50% helpful (1/2)
