How to check the voltage output of a PS-24.
  • How to check the voltage output of a PS-24.
‎2018-09-11 05:54 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:45 AM
Need the pinout for the righthand side connector on the PS-24 to troubleshoot. it.
PS-24, AS, IO Modules
PS-24 had failed with no output to the AS and IO Modules. The pinout for the PS-24 is not documented so was unsure if it was the PS-24 or the AS that failed.
The top row left and second row left are nominal +24VDC and the top row right and second row right are -24VDC.
See also Automation Server Family Hardware Reference Guide p/n 04-13001-03-en, page 33 for more information.
  • 13871
