How to check PCT 2.0 disk size
  • How to check PCT 2.0 disk size
  • StephenYang
    StephenYang
Admiral StephenYang Admiral
‎2025-06-25 06:23 PM
on ‎2025-06-25 06:23 PM
PCT 2.0 shows "503 Service Temporarily Unavailable" error when trying to reach to PCT server.
Project Configuration Tool
The PCT 2 disk has a fixed size limit of 200GB and cannot be expanded by users. Once the disk reaches full capacity, access to PCT 2 becomes unavailable.
  1. Check the size of the "data.vhdx" file:
    • The file resides in the "Virtual Hard Disks" folder.
    • This folder can be found in the path selected during the installation.
  2. Folder location:
    • Navigate to the installation path to locate the "Virtual Hard Disks" folder.
  3. File location:
    • Inside the "Virtual Hard Disks" folder, locate the "data.vhdx" file.
    • Check the size of the "data.vhdx" file.
If the disk size is over 200GB, contact local support and attach the information.
Labels (2)
  • Project Configuration Tool
  • StephenYang25
0% helpful (0/1)
