How to change the default SMTP port in Vista 5.1.5 running on 64-bit operating systems
  • How to change the default SMTP port in Vista 5.1.5 running on 64-bit operating systems
  • sesa177673
    sesa177673
‎2018-09-06 01:51 PM
Window 7 64-bit
Windows 2008 server 64-bit
Vista 5.1.5
The registry key that allows the SMTP port to be changed is located in a different folder when running 64-bit operating systems.
  1. Open the registry editor. Start\run and then type regedit
  2. Go to HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\TAC AB\TAC Vista\5.1.5\SMTP and locate the entry named Port.
  3. Double click on this entry and change it to the desired port number.
  4. Click OK.
(The Wow6432Node folder is a folder that contains information about 32-bit applications being run on 64-bit operating systems).
  • 5117
