How to bring a BACnet controller online after restoring a backup
  • How to bring a BACnet controller online after restoring a backup
Lt. Commander Reza Lt. Commander
‎2022-10-06 10:25 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:33 AM
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
Customers may want to take a backup from a site and use it on other setups. If there would be any BACnet controller under the Backup, they may need to know the process of hosting the BACnet controllers under the restored backup on the physical BACnet controllers.
This video will demonstrate how to bring a BACnet controller online after restoring a backup.
NOTE
After matching up the Device ID of the BACnet controller under the restored server and the Object ID of the physical BACnet controller, if the hosting status shows “Not hosted”, users need to perform a "Repair Hosting". Please refer to Repair Hosting a BACnet/IP controller
  • RezaAmirzadeh22
100% helpful (1/1)
