How to backup the database automatically to the specify path with Continuum Standalone system
  • How to backup the database automatically to the specify path with Continuum Standalone system
  • YangboLIU
    YangboLIU
‎2018-09-06 11:07 AM
Continuum Standalone system use SQL Express without function of maintenance, So other method need to be implemented  to do this task
Cyberstation
SQL Express
Require to backup the database with a record.
  1. Install SQL Server Management  Studio Tools for SQL Express
  2. Backup the database to specify path, such as "D:\backup\ContDB_Mon.bak"
  3. Run SQL Server Management Studio Express and create a new query
  4. Copy the following SQL syntax and paste in this new query then  run it
    EXEC Sp_Addumpdevice 'disk', 'ContinuumDB', 'D:\backup\ContDB_Mon.bak'
  5. Create another new query called ContDB_BU_Mon.sql, copy the following SQL syntax and paste in the query  then run it
    Select getdate() as "ContDB backup startTime"
    go
    BACKUP DATABASE  [ContinuumDB]  TO [ContinuumDB] with Format, INIT,NAME= N'Contdb_Mon Database Backup', SKIP, Norewind, NOUNLOAD, STATS = 10
    go
    select getdate() as "Contdb Backup Endtime"
    go
  6. Close the query above and save it to D:\backup\ContDB_BU_Mon.sql
  7. Create a .txt file with the following command then save it as .bat file
    OSQL -S(Local)\SQLEXPRESS -E -i  "D:\backup\ContDB_BU_Mon.sql" -O  "D:\Backup\Contdb_BU_Mon.log"
  8. From Windows Control panel > Performance and Maintenance > Scheduled Tasks, Add Scheduled Task, select the "Browse" button, find the .bat file you want to run, then set the time schedule you desired.
After the scheduled task created successfully, the database backup will be executed scheduled with record. the record was written in the file Contdb_BU_Mon.log.
  • 11133
