How to backup PCT 2.0
  • How to backup PCT 2.0
Admiral StephenYang Admiral
‎2024-12-16 11:16 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:31 AM
Need to create PCT backup
Project Configuration Tool
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
Users need to backup all PCT data to prevent data loss or corruption.
Since PCT 2.0 virtual machine resides in Hyper-V., the process is the same as backup any VM in Hyper-V Manager.
  1. Open Hyper-V Manager: Launch the Hyper-V Manager application on your server.
  2. Select the VM: Navigate to the virtual machine you want to back up in the left pane.
  3. Right-click and choose "Export": Right-click on the VM and select "Export" from the context menu.
  4. Choose a destination: Select the folder where you want to save the exported VM files.
  5. Start the export process: Click "Export" to begin the backup process.
  6. The "Export" process will create a "pct" folder from the folder in step 4.
  7. The 3 folders under "pct" folder are the backup for PCT 2.0 with projects and server packages installed.
Labels (2)
  • Project Configuration Tool
  • StephenYang24
100% helpful (2/2)
