How to allow access to certain people based on CARD only on a door that requires CARD+PIN
  • How to allow access to certain people based on CARD only on a door that requires CARD+PIN
  • AbeMeran
    AbeMeran
‎2018-09-11 07:31 AM
Site doors are configured for CARD+PIN but they have a short list of people that require the ability to access the door without a PIN
CyberStation
Documentation
Click HERE for a sample PE program that will allow a list of Card Numbers to change the mode of the door to card only so they can gain access without a PIN, the program will switch the door back to CARD+PIN as soon as the special person goes thru the door.
  • 16066
