How to adjust the temperature Display on an ETR100 (1xx)
  • How to adjust the temperature Display on an ETR100 (1xx)
  • Sacco
    Sacco
‎2018-09-07 03:42 AM
Displayed temperature on the ETR is offset from the actual temperature reading of the controller.
ETR
Thermostat
Factory calibration is offset from actual temperature.
Click here to download the Installation and Operating Instructions
Temperature Display Adjustments
Temperature display may be adjusted by adjusting the ZERO or OFFSET Potentiometer (P2) as shown on the diagram.  Adjust P2 until the LCD Display reading, matches your controllers temperature reading if necessary.
Note that all LCD Displays, are factory calibrated using an NIST Certified Glass Thermometer.
Labels (5)
  • Field Devices
  • TAC IA Series
  • TAC INET
  • 4232
