How to add area(s) to multiple personnel objects in one operation
  • How to add area(s) to multiple personnel objects in one operation
  • AbeMeran
    AbeMeran
‎2018-09-06 02:10 PM
Adding area(s) to multiple personnel objects in one operation
CyberStation
Need to add area(s) to multiple personnel objects in one shot
  1. In the Continuum Explorer select the folder that contains the personnel object.
  2. In the right pane select the personnel objects you want to add the area(s) to, you can select ‘Edit\Select All’ from the pull down menu or use a combination of the Shift/Ctrl key with the left button mouse click to multi select.
  3. Right click on one of the selected Personnel objects and select ‘Add Areas…’ from the context menu.
  4. In the ‘Area’ window you can select one or more areas to assign.
  • 4529
