How to add additional fields to the New Search window in the Personnel Manager?
  • How to add additional fields to the New Search window in the Personnel Manager?
  • PaulFr
    PaulFr
‎2018-09-06 02:00 PM
The New Search window shows a set of predefined attributes to search on, can additional attributes be added to this list?
Cyberstation Personnel manager, Versions 1.80 and above.
There is no option to add/ remove fields from the New Search window.
1) The New Search Window entries are fixed, there is no option to add / remove fields in this window.
2) To search on one of the other attributes not listed; use a List View of Personnel to show the required attributes and use a Qualifier on that attribute to prompt the user for the search criteria.
3) The * character can be used as a wildcard, so for example if searching on the Vehicle Info attribute entering Ford* would find all Ford vehicles if the field is used to hold the make & model of vehicles.
  • 4827
