How to Save Layout for Workspace
  • How to Save Layout for Workspace
  • sesa145087_brid
    sesa145087_brid
‎2018-09-11 07:32 AM
When there are multiple panels or graphics assigned to a Workspace, sometimes the layout will be in a mess when viewing it.
SmartStruxure
The layout for Workspace needs to be manually arranged and saved.
After manually arranged the layout for Workspace, you need to click on the View menu and select "Save workspace layout" to save it. This work needs to be done per user, which means if you have multiple users using this Workspace, you need to log on with each user and save them separately. To set the layout back to the default, go to the View menu and select "Reset workspace layout".
  • 16098
