How to Retrieve Log values from TAC Vista MSSQL Database
  • How to Retrieve Log values from TAC Vista MSSQL Database
‎2018-09-09 09:48 PM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:55 AM
TAC Vista and MSSQL Database
Requires third party access to retrieve Log Values from TAC Vista MSSQL Database
1. Refer to the attached PDF document for the procedure
2. Note: You’re limited to retrieve only one log object at a time
  • 5258
