How to Logon / Logoff Continuum using a button on a Graphic or Menu page.
  • How to Logon / Logoff Continuum using a button on a Graphic or Menu page.
‎2018-09-06 11:26 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:58 AM
Continuum Cyberstation
Want to be able to Logon Continuum with the click of a button from Graphics or Menu page and also bring up the Logon prompt the same way.
** DISCLAIMER ** This application is not a supported part of Continuum and is provided as-is.
1. Copy the "Logoff.tx_" file in this archive, here, to the Continuum folder (c:\Program Files\Continuum).
2. Rename the .tx_ file extension to .exe.
3. Create hotspots / buttons as below to call the program with the two available command line arguments; 1 will logon, 2 will logoff.
Suggested usage:
On the Main Continuum Menu page create two buttons, one for logon, one for logoff. (Pinpoint could also be used for Logoff but would not work for Logging back on - Pinpoint closes when the user is logged off.)
For the Logon Button:
                Set control to:        Execute
                Open:                     C:\ProgramFiles\Continuum\Logoff.exe
                Arguments:             1
                Button Text:           Logon
For Logoff Button:
                Arguments:             2
                Button Text:           Logoff
Logoff Continuum.zip
  • 10889
