How to Link to a Web Page using I/NET graphics
  • How to Link to a Web Page using I/NET graphics
  • sesa139513
    sesa139513
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-07 08:26 AM
I/NET 2.xx
The following example describes how to create a tool that will open http://www.msn.com in your system's default web browser.
  1. Using Notepad, create a new text file and type the following line of text:
    start http://www.msn.com
  2. Save the file to your PC as OpenMSN.bat.
  3. Open the I/NET graphic you are editing
  4. Select, I/NET>Tool Marker
  5. In the Tool Details section, click SELECT
  6. In the User Tool Configuration Window click on Add, then name your tool and select shortcut.  Click OK
  7. When the file selection dialog appears, select the OpenMSN.bat batch file that you just created.
  8. Define the label and icon of your tool and press okay.
  • TAC INET
  • 4288
