How to Identify if SQL Server is 32-bit or 64-bit
  • How to Identify if SQL Server is 32-bit or 64-bit
  • Katha
    Katha
Lt. Commander Katha Lt. Commander
‎2025-10-06 05:55 PM
on ‎2025-10-06 05:55 PM
A malfunction in Power Monitoring Expert (PME) may occur due to the installation of a 32-bit version of SQL Server.
The issue may stem from using a 32-bit SQL Server, which is incompatible or suboptimal for PME.
You can determine the SQL Server architecture using either of the following methods:
Method 1: Using SERVERPROPERTY
  1. Open SQL Server Management Studio (SSMS) and connect to the target SQL Server instance.
  2. Click New Query.
  3. Ensure the master database is selected.
  4. Run the following query:
    SELECT CASE
             WHEN CHARINDEX('64', CAST(SERVERPROPERTY('Edition') AS VARCHAR(100))) > 0
             THEN 64
             ELSE 32
           END AS [SQL Server Bit Version];
  1. Click Execute.
🔍 Result: The query returns either 32 or 64, indicating the bit version of the SQL Server instance.
Method 2: Using @@VERSION
Alternatively, run the following query:
SELECT @@VERSION;
🔍 Example Output:
Microsoft SQL Server 2008 R2 (SP1) - 10.50.2550.0 (X64)
Standard Edition (64-bit) on Windows NT 6.1 (Build 7601: Service Pack 1)
Look for (X64) or (32-bit) in the output to determine the architecture.
  • KatharineVasquez25
