How to Disable Sigma Controller Offline Hardware and Other Alarms
  • How to Disable Sigma Controller Offline Hardware and Other Alarms
  • CraigEl
    CraigEl
  • Gary
    Gary
Gary Schneider Alumni (Retired)
‎2022-10-02 05:18 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-30 12:26 AM
Unwanted hardware alarms (and other alarms) are being received at the Enterprise Server from Sigma controllers.
Satchwell BAS & Sigma, EcoStruxure Building Operation
  • Sigma Release 4_08 (Build 3_46_57)
Sigma controllers are configured to send hardware and other system alarms to the Enterprise Server, which may not be required in certain operational contexts.
To disable these alarms:
  1. Access the Sigma Interface:
    • Navigate to the Sigma interface within EcoStruxure Building Operation.
  2. Locate the Controller (OSN):
    • Identify the controller from which you want to disable alarms.
  3. Modify Device Monitoring Settings:
    • Select the controller.
    • Go to the Basic tab in the Properties panel.
    • Locate the Device Monitoring setting.
    • Set it to Disabled to stop hardware and system alarms from being sent.
  4. Bulk Update (Optional):
    • If multiple controllers need to be updated:
      • Multi-select the required controllers.
      • Open the Property Panel.
      • Change the Device Monitoring setting for all selected controllers simultaneously.
Labels (2)
  • Satchwell BAS & Sigma
Tags (2)
  • CraigEllis25
  • GaryMontague22
100% helpful (1/1)
