How to Check Installed PME and CU Versions
  • How to Check Installed PME and CU Versions
  • Katha
    Katha
Lt. Commander Katha Lt. Commander
‎2025-10-06 05:08 PM
on ‎2025-10-06 05:08 PM
How to check installed Power Monitoring Expert (PME) and Cumulative Update (CU ) versions.
EcoStruxure Power Monitoring Expert
When troubleshooting integration issues between Power Monitoring Expert (PME) and EcoStruxure Building Operation (EBO), it's important to identify the installed PME version and its corresponding Cumulative Update (CU). Knowing the exact PME and CU versions helps ensure compatibility and can assist in diagnosing integration problems between PME and EBO.
To check the installed PME and CU versions:
  1. Open the Windows search bar and type regedit.
    Press Enter to launch the Registry Editor.
  2. Navigate to the following registry path:
    Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\Power Monitoring Expert\X.X\CumulativeUpdate
  3. Review the values listed under this path.
    These entries will indicate:
    • The installed PME version
    • The Cumulative Update (CU) version, if applicable
  • KatharineVasquez25
