How many member objects can be added to a Continuum Report?
  • How many member objects can be added to a Continuum Report?
  • PaulFr
    PaulFr
‎2018-09-06 07:53 AM
The documentation does not specify how many  objects can be added in the filter tab of a report.
Cyberstation Workstation creating a Report
Adding too many objects produces the following error:
"There are too many objects in the filter Member Objects lists."
The maximum number of member objects you can add to a report is 150 objects.
Exceeding 150 will produce the above error.
  • 19246
