How many animations can I have on a Pinpoint graphic?
  • How many animations can I have on a Pinpoint graphic?
  • sesa139513
    sesa139513
  • PaulFr
    PaulFr
‎2018-09-06 10:10 AM
What determines haw many active animations a graphic can have?
Cyberstation Pinpoint graphics.
Graphic updates will slow down if an excessive number of animations are configured.
50 Animations on a graphic is a good limit that should give a reasonable update rate on most systems. In the Pinpoint editor you can change the polling rate of each animation from the default 1000mS allowing less important points to be polled less, thus allowing the important points to be polled more. In Edit mode; go to Configuration, Object List to see the polling rates listed, each animation allows you to change its polling rate.
It is generally better to have more graphics with fewer animations for faster updates.
The rate at which you can poll for updates will also depend on your system layout, a system with many animations being polled from large slow MS/TP of Infinet field bus network will update much slower than a system with NetcontrollerII and IO modules with all points connected at the Ethernet level.
No Pinpoint animations poll from the SQL database, all data is polled directly from the controller that holds the Animated object. When a graphic is opened the Workstation goes to the SQL Server to get the background file and the location of all polled objects, it will then directly poll the field controllers with no further need to connect to the SQL database.
  • 14018
