How many IO Modules can fit in the universal enclosures?
  • How many IO Modules can fit in the universal enclosures?
‎2018-09-10 01:14 PM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:53 AM
Panel layout.
 ERG-UNIV-ENC-1
ERG-UNIV-ENC-2
Need to determine panel layout for a project using the universal enclosures.
From the data sheet...
Medium Enclosure:
Andover Continuum Power Supply and NetController, and up to two I/O modules or up to six I/O modules or CX 9702 SiteController.
Small Enclosure:
Up to three I/O modules or CX 9702 SiteController or NetController (without a Power Supply) or VS-8-4 Video Switch Module.
Both units are designed to hold two standard 12 VDC 7AH lead acid batteries (not provided).
See the full data sheet here.
  • 11328
