How does a Menta application execute?
  • How does a Menta application execute?
‎2018-09-06 03:24 PM
Menta
Menta applications use parallel computing. All updates are simultaneous. There is no order by object name or number. Location of objects on the page has nothing to do with execution.
Menta applications update all objects simultaneously. On the first program cycle, the outputs of all objects are updated based on initial values within all of the blocks. On the next sweep, all inputs are updates from external values or outputs from upstream objects. All outputs are then updated from the new inputs. This process then continues.
  • 1186
