How do I verify that the File Equalization DLL file is current?
  • How do I verify that the File Equalization DLL file is current?
  • sesa139513
    sesa139513
  • Tom_Poovey
    Tom_Poovey
‎2018-09-06 02:49 PM
I/NET site
Checking to make sure the File Equalization DLL file is current
You need to go on the PC to the following location:
C:\Program Files\Inet Seven
Scroll down the list of files until you find this "DLL" file, "INetEqzCR.dll". Highlight this file and do a right mouse click. In the next popup window choose the "properties" option. In the next window select the "Version" tab. Verify that version listed matches the Host load and the build number of the I/NET Seven.
  • TAC INET
  • 2986
