How do I set the address for the 78010 Tap?
  • How do I set the address for the 78010 Tap?
  • sesa139513
    sesa139513
‎2018-09-06 03:18 PM
I/NET site
Positions 1,2, and 3 of DIP switch SW1 define the TAP address. This address identifies the Tap when connecting through I/NET software. The Tap address can be set at 0 - 7 when direct connecting to a host LAN, and it will always be address 0 when connecting to a controller LAN. The switches are binary with their values being active when in the up position.
  • TAC INET
  • 1467
