How do I read the feedback voltage from a DuraDrive actuator (MS4x / MS5x series) with MNL / MNB controllers
  • How do I read the feedback voltage from a DuraDrive actuator (MS4x / MS5x series) with MNL / MNB controllers
  • sesa116868
    sesa116868
‎2018-09-10 03:16 AM
DuraDrive actuator feedback is 0-10 VDC or 2-10 VDC, controllers accept 0-5 VDC.
The voltage feedback output was designed for controlling slave actuators configured for 0-10 VDC or 2-10 VDC control signals.
Use two 10k resistors as a voltage divider across the feedback leads with the center point connected to the controller input and the actuator common connected to the controller common.
Voltage Divider
NOTE: Not all actuators in this product family use the wire colors shown for the feedback output. Please refer to the actuator GI sheet for the correct colors.
 MNL / MNB Controller Analog Input Configuration
For actuators with a 0 VDC to 10 VDC feedback output:
Type= Volts
Linput = 0
Lscale = 0
Hinput = 5
Hscale = 100
This input configuration provides a 0 - 100% output corresponding to the Actuator Position, based on feedback voltage 0 VDC = 0% and 10 VDC = 100% of actuator travel.
For actuators with a 2 VDC to 10 VDC feedback output:
Type= Volts
Linput = 1
Lscale = 0
Hinput = 5
Hscale = 100
This input configuration provides a 0 - 100% output corresponding to the Actuator Position, based on feedback voltage 2 VDC = 0% and 10 VDC = 100% of actuator travel.
  • TAC IA Series
  • 6313
100% helpful (1/1)
