How do I put a different application in an existing MNL controller under an AS?
AS with MNL controllers
Warning
An incorrect application has been installed in a device.
First, the correct application must exist in the WorkPlace Tech editor list.
Expand the System Tree to expose the MNL device to be changed and the Application file under it. Right click on Application and select delete.
Now right click on the MNL controller select MNL and Assign application and assign the correct application from the list.
Once assigned right click on the controller select MNL and select Download application.
