How do I create a Multi-Columned report for an A-Sample Trend?
  • How do I create a Multi-Columned report for an A-Sample Trend?
  • Tom_Poovey
    Tom_Poovey
‎2018-09-07 03:04 PM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-08 01:47 PM
Using I/NET Seven and Sub Reports (Seven Reports)
TAC INET
I/NET Seven 2.21 and below
In most BMS systems the most common report was a tabular (or column report) of data. Seven Reports (Crystal Reports) did not provide this facility easily.  Although it can be achieved using the subreport feature within Seven Reports.
The Steps to create this report are discussed in the following link. Subreports process w screen captures.doc
  • TAC INET
  • 1753
