How can you tell the difference between a I2/B3xxx -V and a I2/B3xxx controller through Continuum Explorer?
  • How can you tell the difference between a I2/B3xxx -V and a I2/B3xxx controller through Continuum Explorer?
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:46 PM
  • I2/B3xxx
  • I2/B3xxx -V
Determine the version of a controller remotely through Continuum Explorer
  1. In Continuum Explorer, right click to edit a I2/B3xxx -V controller
  2. Select the runtime tab
  3. Looking at the version of the controller is the way to distinguish between the different Models.
    • The I2/B3xxx -V will have a version number similar to 3.501027
    • A regular I2/B3xxx will have a number similar to 3.300006.
    • Notice the location of the 1 in the -V version number. The -V models will have the 1 in the location as above while the non -V model will not.
  • 3117
