How can the default graphic for the Monitor Screens be modified in SIGNAL?
  • How can the default graphic for the Monitor Screens be modified in SIGNAL?
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 12:57 PM
SIGNAL (all versions)
A re-installation of SIGNAL from floppy restores a default graphic called _MAINMAP.SSF when clicking on the Monitor Screens.
Sign onto SIGNAL with administrative privileges and click on the Edit drop-down menu.  Select Edit Button.
The mouse changes to a hand with an index finger pointer.  Select the Monitor button.  The pop-up below will appear:
Change the filename _MAINMAP.SSF to the desired ssf file and click Save/Done.
  • TAC IA Series
  • 6919
