How can the default HTTP port for a Niagara R2 UNC station be changed?
  • How can the default HTTP port for a Niagara R2 UNC station be changed?
  • sesa119747
    sesa119747
  • sesa116871
    sesa116871
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:56 PM
The station need to change the default port 80 to a non-standard HTTP port in the httpPort text box.
Do the following:
  1.  In WorkPlace Pro, open the station offline
  2. In the tree view, right-click on the offline station and select Go - Properties
  3. On the Properties sheet, click the Config tab
  4. Edit the httpPort text box, removing the default port of 80 and replacing it with your chosen port number (e.g. 8081)
  5. Click Apply
  6. In the tree view, right-click on the offline station and select Close
  7. Open the Admin Tool, and log into the UNC
  8. Right-click the station name (not the host name or address) and select Edit - Properties. This opens the station.properties file
  9. Add the following line to the station.properties file:  httpPort=[newport] (newport = port number from step 4), example httpPort=8081
  10. From the file menu, choose File - Close. The system will prompt you to save any changes. Choose Yes.
  11. In the Admin Tool, click the Installation tab
  12. On the Installation Sheet, click Install Station
  13. Select the station from step 4, then click OK
  14. In the Confirm dialog box, click Yes
  15. In the Select Database Format dialog box, select the DB radio button, then click OK
  16. The system will load the offline database to the UNC, then re-boot the station. When finished, the message box will display "Installation Complete"
  • TAC IA Series
  • 2686
