How can a graph displaying two points in WorkPlace Pro be created?
  • How can a graph displaying two points in WorkPlace Pro be created?
  • sesa116877
    sesa116877
‎2018-09-06 02:51 PM
  • Workplace Pro
  • Trend log graph
Displaying two points' trend data on a single graph allows the user to compare two values over time.
Using return air temperature and supply air temperature as an example:
  1. In the logic folder, link these two objects to an analog log object using status output to status input.
  2. Open a web browser and type the SWID http://IPaddress/chart/log.
  3. In the log window, hold down the CTRL key and select multiple logs and click on ADD and click Chart. This will create a chart with multiple points. Continue the following steps to access it from the browser:
  4. In the chart window, copy the URL address and create a gx text on a gxpage.
  5. Go to the properties of the gxtext and select the visual tab.
  6. On the hyperlink URL paste the address in the space.
  7. On hyperlinkonclick select URL, go to the configure tab and type text in the box that will display in the browser.
  8. Open a web browser and type in this SWID http://IPaddress/gx/index. This will display the list of graphics, select one and select the gxtext. This will launch to the graphics page.
  • TAC IA Series
  • 2908
