How can I get the navigation tree back when I changed the menu frame for the root user?
  • How can I get the navigation tree back when I changed the menu frame for the root user?
  • sesa150555
    sesa150555
‎2018-09-06 02:20 PM
Under user admin in a Xenta server you can change the content of the 3 frames that the user sees when logging in.
If the user have changed the default frames for the root user in a Xenta server so that the tree navigation is not available you can't navigate back to user admin to reset the frames.
  • TAC Xenta Server
  • Xenta 511, 527, 555, 701, 711, 721, 731, 913
User have changed the frames so that the menu tree is no longer available
  1. Log on to the Xenta server with the root account.
  2. Type in https://xx.xx.xx.xx/wm/useradmin/ in the IE address field.
  3. This takes you directly to the useradmin page.
  4. Click on the root user.
  5. Under Frame Settings click on Use Default for the Menu frame.
Labels (2)
  • TAC INET
  • 4201
