How can I change the colors for Vista alarms in Vista Webstation?
  • How can I change the colors for Vista alarms in Vista Webstation?
  • SESA116857
    SESA116857
‎2018-09-06 03:02 PM
  • TAC Vista Webstation
  • Alarm queue
Customize the color palette for a Webstation user.
  1. To change the colors used by alarms in Vista Webstation, log in to Vista Workstation as a user that belongs to the $Administrator group.
  2. Right click on an alarm and select customize.
  3. In the Text tab, you will be able to change the font color or background color for each of the alarm states.
  4. Once you have configured the colors to your liking use the File->Save My Program Settings command.
  5. The change will now be visible in Vista Webstation next time you log back in.
  • 2345
