How can BACnet objects be learned as "full" objects and not "lite" objects in a Niagara R2?
  • How can BACnet objects be learned as "full" objects and not "lite" objects in a Niagara R2?
  • sesa119747
    sesa119747
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:53 PM
How can BACnet objects be learned as "full" objects and not "lite" objects in Niagara R2?
Niagara R2
"Use lite objects" is enabled and need to be disable (uncheck the box) "Use Lite Objects" setting using BACnet Utilities.
From the BACnet Utilities window, when performing either a "network - learnNetwork" or "device - learnDevice" command, clicking the Execute button will generate a pop-up window. In this window, uncheck "Use lite objects", and click OK to proceed.
  • TAC IA Series
  • 2816
