How are expander modules wired in to the SP-ACX?
  • How are expander modules wired in to the SP-ACX?
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2023-06-28 12:18 AM
Controller labelling and documentation does not describe how to connect expander modules or which modules are supported.
EcoStruxure Security Expert
  • Security Expert
  • SP-ACX
  • SP-ACX-V2
  • SP-O8
  • SP-I16
  • SP-MRDM2
  • SP-RDM2
  • SP-I01
  • SP-IO84
  • SP-MI16
Documentation is scheduled to be updated but due to UL certifications for some of these documents the process may take some time to complete.
  1. Expander modules are able to be connected to the SP-ACX and SP-ACX-V2 controllers. There is no restriction to the type of Expander Module, all modules are supported unless specifically stated that they are not.
  2. The Expander Module network is connected to the RS-485 port on the right-hand side of the controller just above the Digital Outputs port. This port should be labelled with N+, N-, NA, NB and is to be wired up as per the below diagram.
    Expander Module RS-485 portExpander Module RS-485 port
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele23
  • AdamSteele24
