How I/NET 2.3X has the ability to designate a particular host to do an automatic restore
  • How I/NET 2.3X has the ability to designate a particular host to do an automatic restore
  • sesa139513
    sesa139513
‎2018-09-06 03:26 PM
I/NET site
Go to the host’s Network Configuration/Link Summary. Highlight the desired row. In that row you will find a column labeled “R/H”. This stands for Restore-Host. Modify this row. In the Restore Host prompt, place the same host number you entered in the host’s active Configuration Profile.
(Don't forget to make sure that host has current save files!)
  • TAC INET
  • 1093
