High temperature application valve selection
  • High temperature application valve selection
  • SESA150559
    SESA150559
‎2018-09-06 10:38 AM
In some applications, a valve with higher temperature range is required.
High temperature valve
VGS211F:
VGS211F-15CS03
VGS211F-15CS04
VGS211F-15CS05
VGS211F-15CS07
VGS211F-15CS08
VGS211F-20CS
VGS211F-25CS
VGS211F-32CS
VGS211F-40CS
VGS211F-50CS
VGS211F-65CS
VGS211F-80CS
VGS211F-100CS
High temperature application.
The only valve currently listed in our portfolio that is capable of temperatures up to 200°C is the VGS211F valve.
  • Field Devices
Tags (2)
  • 12586
  • hot
