Heat meter options
  • Heat meter options
  • SESA150559
    SESA150559
Heat meter options
‎2018-09-06 10:54 AM
Is it possible to order a LON or MBUS base module separately after the main order of the heat meter is done, to complete the setup?
Multical
heat meter
heatmeter
MAMBUSBASE  Replacement Mbus Base Module
MALON BASE  Replacement LON Base Module
If the base module was not ordered during original purchase, it may be necessary to order separately.
The base modules can be ordered separately afterwards to complete the setup:
MAMBUSBASE - Replacement Mbus Base Module
MALON BASE - Replacement LON Base Module
  • Field Devices
  • 11727
