Health status shows "too many remote controllers assigned" message
  • Health status shows "too many remote controllers assigned" message
Guinan AdamSteele Guinan
‎2020-06-22 04:22 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:43 AM
Controller Health Status shows, "Controller (ID **) has too many Remote Controllers assigned." What does this message mean, and is it a cause for concern?
Security Expert
  • Security Expert Client
  • SP-C Controller
This error message is related to cross controller communication. When using cross controller communications, the maximum number of controllers that can be linked together is 64. For additional details on cross controller communications, see page 4 of AN 180 Security Expert - Cross Controller Operations - Integration Guide.
The controllers that are not taking part in cross controller linking are the ones that are showing the "Controller (ID **) has too many Remote Controllers assigned." message.
  • Evaluate what values/controllers are being shared to ensure your programming is performing as expected. See AN 180 Security Expert - Cross Controller Operations - Integration Guide for further details on cross controller communications and which values use this.
  • Limit the number of sharing controllers to 64 or split the controllers up into two systems.
  • EcoStruxure Security Expert
Tags (3)
  • AdamSteele20
  • AdamSteele23
  • HernanUruena24
100% helpful (1/1)
