Has a Universal Input module sending out voltage needs to understand why its doing this.
  • Has a Universal Input module sending out voltage needs to understand why its doing this.
  • AbeMeran
    AbeMeran
‎2018-09-06 09:38 AM
Configured a digital input on SXW-UI16, with nothing connected to the input used a volts meter to measure the voltage between RET and the input, the volts meter reads 20.3. Why?
SXW-UI16
Other modules
This is normal, what is being measured is the voltage across the pull up resistor on the input circuitry.
Any sensor attached to the input must be able to handle the voltage.
Labels (2)
  • 15895
