HID Proxpro with keypad
  • HID Proxpro with keypad
  • sesa139513
    sesa139513
  • Carl_Slack
    Carl_Slack
‎2018-09-06 03:04 PM
Applies to both I/NET and Continuum door controllers.
Information pertaining to the HID ProxPro
When ordering a keypad reader from HID, you need to make sure the Configuration Setting option is "09 - Buffer one key, add compliment, 8 bit message (Dorado)".
Example: 5355 AGK 09 - ProxPro w/ Keypad
If you are using the 5535 model reader on an Infinity ACX781 or ACX780 model controller you will need to order with Configuration Setting option 00.
Labels (2)
  • TAC INET
  • 2062
