Graphics not functioning after moving I/NET to a new machine that uses direct serial connection
  • Graphics not functioning after moving I/NET to a new machine that uses direct serial connection
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 12:52 PM
Points are not displaying data but links between pages still work.
I/NET Seven
Direct Connect
I/NET link and station numbers must be correct for I/NET graphics to work
You can verify that this is the issue by editing a graphic and determine the link address of a displayed point. If this link is not available when you try to connect to the controller then you will need to change your I/NET configuration.
  1. Open I/NET Configuration
  2. Modify the Active Profile
  3. Ensure that the System and Hardware Addresses configured match the configuration of the original computer
  • TAC INET
  • 6968
