Grant momentary release on a door without ability to modify points
  • Grant momentary release on a door without ability to modify points
‎2018-09-06 03:24 PM
I/NET DPU
One application would be security guards. You want to grant the guards the ability to momentary - release any door, but do not want to give them the ability to modify points.
Give them access to only graphic pages. These pages should have internal DOs or internal DIs . Since these discrete points are two state, they can be used to trigger event sequences that will only open the doors for brief periods.
Last and of course not least, go to the guards host passwords (not your host password), and remove any function you do not want them to have. You will need "Live Graphic Page" and probably several other functions, so you will have to customize this set up to fit your situation.
  • TAC INET
  • 1223
