Getting the errors "Error resolving www.weather.gov java.net.UnknownHostException: www.weather.gov - Authoritative Answer Host not found"
  • Getting the errors "Error resolving www.weather.gov java.net.UnknownHostException: www.weather.gov - Authoritative Answer Hos...
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 01:23 PM
Getting error for Weather Server:
 ERROR [19:32:28 06-Sep-11 EDT][http.proxy] Error resolving www.weather.gov
   at java.net.InetAddress.lookupHostByName(InetAddress.java:369)
   at java.net.InetAddress.getByName(InetAddress.java:221)
   at javax.baja.naming.BIpHost.getInetAddress(BIpHost.java)
   at javax.baja.net.BHttpProxyService.get(BHttpProxyService.java)
   at javax.baja.net.HttpConnection.connect(HttpConnection.java)
   at com.tridium.weather.nws.advisory.BNwsAdvisoryAlarmExt.getFeed(BNwsAdvisoryAlarmExt.java)
   at com.tridium.weather.nws.advisory.BNwsAdvisoryAlarmExt.getAdvisories(BNwsAdvisoryAlarmExt.java)
   at com.tridium.weather.nws.BNwsWeatherProvider.updateReport(BNwsWeatherProvider.java)
   at javax.baja.weather.BWeatherReport.doUpdateWeatherReport(BWeatherReport.java)
   at auto.javax_baja_weather_BWeatherReport.invoke(AutoGenerated)
   at com.tridium.sys.schema.ComponentSlotMap.invoke(ComponentSlotMap.java)
   at com.tridium.sys.engine.EngineUtil.doInvoke(EngineUtil.java)
   at javax.baja.sys.BComponent.doInvoke(BComponent.java)
   at javax.baja.util.Invocation.run(Invocation.java)
   at javax.baja.util.Worker.process(Worker.java)
   at javax.baja.util.Worker$Processor.run(Worker.java)
   at java.lang.Thread.run(Thread.java:823)
WARNING [19:32:29 06-Sep-11 EDT][weather] Unable to load advisories for zone MIZ061
   at java.net.InetAddress.lookupHostByName(InetAddress.java:360)
   at javax.baja.naming.BIpHost.openSocket(BIpHost.java)
ERROR [19:32:29 06-Sep-11 EDT][http.proxy] Error resolving www.nws.noaa.gov
java.net.UnknownHostException: www.nws.noaa.gov - Authoritative Answer Host not found
   at com.tridium.weather.nws.NwsCurrentReader.getFeed(NwsCurrentReader.java)
   at com.tridium.weather.nws.NwsCurrentReader.getCurrent(NwsCurrentReader.java)
WARNING [19:32:30 06-Sep-11 EDT][weather] Updating current conditions failed for WeatherReport
Niagara G3, Workbench all versions
No address entered for DNS or IP Address incorrectly entered.
Configuration for the DNS is located under the ENC/ENS Platform.
  1. Open the Platform
  2. Select TCP/IP
  3. Enter the IP address for the DNS in the DNSv4 Servers slot and save changes.
The network administrator should be able to provide the correct DNS address.
  • TAC IA Series
  • 5992
This is a heading
