Getting the error message:"You may only install 3.301.529.v1 with this version of the wizard." when trying to install 529 to new UNC.
  • Getting the error message:"You may only install 3.301.529.v1 with this version of the wizard." when trying to install 529 to ...
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 12:59 PM
Getting the error message: "You may only install 3.301.529.v1 with this version of the wizard." when trying to install 529 to new UNC. WorkPlace Pro will not proceed with install.
Niagara R2, all versions
The wrong installation folder was selected in the Installation Wizard.  The nre folder was selected in place of the emb folder.
Run the Installation Wizard again this time selecting the emb folder.
  • TAC IA Series
  • 6751
