Getting error message when selecting Char set file for Xenta OP in EBO
  • Getting error message when selecting Char set file for Xenta OP in EBO
  • RandyDavis
    RandyDavis
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2021-05-06 11:25 AM
on ‎2021-05-06 11:25 AM
Getting error message when selecting Character set file for the TAC  Xenta Operator Panel (OP).
EcoStruxure Building Operation, TAC Vista, Xenta OP
  • TAC Xenta OP
  • Microsoft Windows 10
Microsoft Windows 10 does no longer allows the software to change files in all directories.
  1. Manually open up the directory C:\Program Files (x86)\Schneider Electric EcoStruxure\Building Operation 3.2\WorkStation\CharSet.lib
  2. Select the Charset you want to use, depending on the language, and copy the file.
  3. Remove the extension, so that the file is named Charset, without any extension.
  4. Manually open up the directory C:\ProgramData\Schneider Electric EcoStruxure\Building Operation\WorkStation\Function Block Editor
  5. Paste the copied file here.
Labels (2)
  • MikaelKrantz21
