Getting error 'Failed to access IIS' when starting webstation.
  • Getting error 'Failed to access IIS' when starting webstation.
  • Sacco
    Sacco
‎2018-09-06 02:55 PM
TAC Vista Webstation
This happens if IIS is installed before .NET Framework.
It is necessary to register ASP.NET with IIS.
  1. From the Windows Start Menu>Run
  2. In the Run window type "cmd" to open the command prompt window
  3. To register ASP .NET 2.0, In the command prompt window, type  "%windir%\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -i"
  4. To register ASP .NET 4.0,  In the command prompt window, type "%windir%\Microsoft.NET\Framework\v4.0.30319\aspnet_regiis.exe -i"
This command will re-register ASP.NET as if it were installed after IIS.
  • 2731
