Getting data from Rayleigh Instruments RI-78-80-C kWh Meter
  • Getting data from Rayleigh Instruments RI-78-80-C kWh Meter
‎2018-09-11 07:08 AM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:54 AM
How to get data from Rayleigh Instruments RI-78-80-C kWh power meters
  • EcoStruxure Building Operation Automation Server (ASP/ASB)
  • Modbus RTU Interface
The RI-78-80-C meter provides a single 48-bit Modbus RTU word representing energy in kWh. This word spans three 16-bit registers (registers 0, 1, and 2). The meter:
  • Only responds to a valid 48-bit read
  • Does not return exceptions for invalid or partial register reads
To successfully read the 48-bit value:
Step-by-Step Instructions
  1. Create a Modbus Group
    • Set an appropriate polling interval.
  2. Add Registers
    • Add three 16-bit unsigned registers to the group:
      • ModReg0 (Register 0)
      • ModReg1 (Register 1)
      • ModReg2 (Register 2)
  3. Create an Analog Value
    • Example name: kWReading
  4. Script Program
    • Use the following calculation:
      kWReading = ((256 * 256 * ModReg0) + (256 * ModReg1) + ModReg2) / 100
    • This formula accounts for the fact that each register only uses half of its 16-bit range (values from 0 to 255).
    • The register values represent 1/100 of a kWh, so a scaling factor of /100 is applied.
  5. Bind Points
    • Bind the Modbus registers and analog value to the script program.
Example Calculation
If:
  • ModReg0 = 3
  • ModReg1 = 167
  • ModReg2 = 59
    Then:
    kWReading = ((3 × 256 × 256) + (167 × 256) + 59) / 100
              = 239419 / 100
              = 2394.19 kWh
Additional Notes
  • The device may appear online in EcoStruxure even if it’s not responding correctly.
    • This is because the online poll interval mechanism expects a response from a 16-bit register.
    • Since the RI-78-80-C doesn’t respond to invalid reads, it may falsely appear online.
    • To avoid this, set the online poll interval mechanism to “Inhibit”. GavinHe_0-1755100617955.png
Compatibility Warning:
  • This device may not function correctly in v2.0 and v3.0 due to changes in offline detection.
  • This issue is resolved in v3.1.
Resources
  • Example Modbus Objects and Script
  • RI-78-80-C Exports.zip
Numeric Output kWReading
Line Calc1
kWReading = ((256*256*ModReg0) + (256*ModReg1) + ModReg2)/100
Tags (3)
  • 18261
  • DavidShore20
  • GavinHeward25
